HELP Replacing Rudder on mk3
PostPosted: Sat Apr 13, 2013 10:33 pm
by dutyfirst00
I need to replace a rudder on a mk3 does anyone plans
Simmo on Marrakesh
dutyfirst00@bigpond.com
Re: HELP Replacing Rudder on mk3
PostPosted: Mon Apr 15, 2013 6:51 pm
by Ianb
Scroll down in this sub-forum to "Reef Shoe Bearing " post- there is some design info. viewtopic.php?f=6&t=1340
PostPosted: Fri Aug 23, 2013 1:10 pm
by Ianb
Phill- Looking at your photo showing dropping the rudder on Seaka, do you have the dimension of clearance required under the keel to allow the rudder stock to be completely slid out of the tube? Would be good to have it for reference.
PostPosted: Fri Aug 23, 2013 4:40 pm
Ian,
From memory it's at least 800mm.
I will check my notes and confirm that dimension.
