Rudder bushes
Re: Rudder bushes
Postby freetasman » Sat Apr 23, 2022 6:57 pm
Thank you Steve for the help.
I will remove the rudder if the surveyor does not like how it is.
If I have to remove it I was thinking if was possible to pack the boat above blocks to have about 1 metres clearance.
The Kettering marina have very good gear and expert personnel which handling very large and expensive yachts so I am not anticipate any problems if "Murphy" is not there :D
freetasman
Re: Rudder bushes
Postby freetasman » Sat Apr 23, 2022 9:35 pm
I just found out that there is a pit on the Kettering marina so it will be of a good help.
I would like to have the ss bolts on hand so any of you remember how long are the 3/8 bolts and if I need washers?
For this application do I go for locking nuts or Locktite will be better?
I am trying to get the much parts available on hand to avoiding wasting time on trips to Hobart.
Thanks again for the awesome help.
Cheers, Arthur
freetasman
Re: Rudder bushes
Postby steve » Sun Apr 24, 2022 10:02 pm
Hi Arthur,
Unfortunately I cannot remember the lengths of the bolts.  If you don't have a convenient supplier of bolts, maybe you could use threaded rod as Phillip suggested. A 1m length will be more than enough, 0.5m would probably do.  There are only three bolts in mine, and a mate's Mark 3 also has only three bolts, so this may be the standard arrangement.
Washers are not required.
I don't know what the life expectancy of Nyloc nuts is underwater so I would be inclined to use a marine sealant, or Locktite if it claims a long life underwater, or locking nuts as Phillip suggested.
I found that some of the polyester putty came away with the shoe, and some remained attached to the fibreglass.  I removed it all from the shoe and all the loose stuff from the fibreglass, which left large cavities between the shoe and fibreglass. I used epoxy mixed with filler between the shoe and fibreglass.  I was concerned that I would not be able to remove the shoe in future if the epoxy stuck to the shoe too well.  To prevent this I wrapped the shoe in clingfilm and wrapped PTFE tape around the bolts.  I removed the tape at the ends of the bolts and used Sikaflex around the ends and nuts.  Hopefully that will stop the nuts coming off.  I don't really know whether I did things right.
There was a thread in 2017 discussing the shoe and bearings which you may find interesting.
viewtopic.php?f=6&t=1980
steve
Re: Rudder bushes
Postby steve » Sun Apr 24, 2022 10:52 pm
Hi Arthur,
Unfortunately I have misled you about the size of the bush. I have just found my invoice from Vesco. It was 25mm ID, 30mm OD, rather than 1 inch. I hope that you can change your order. If not, I am sure you could cut the bush and squeeze it to fit.
steve
Re: Rudder bushes
Postby freetasman » Mon Apr 25, 2022 6:48 am
Thank you Steve, I have time to change the size of the bushes so will be OK.
The fasteners supplier is only 20 km from Kettering so it will be OK.
freetasman
Re: Rudder bushes
Postby Phillip » Tue Apr 26, 2022 4:25 pm
freetasman wrote:I just found out that there is a pit on the Kettering marina so it will be of a good help.
Cheers, Arthur
threaded ss rod of 8mm dia, 2x 100mm and 2x 110mm. Use two locking nuts per rod.
