forestay refitting.
Re: forestay refitting.
Postby Shaun » Tue Aug 23, 2016 9:41 am
I dont know a lot about furlers, but are you able to feed the wire in from top or bottom, & put a Sta-Lok fitting top & bottom, then remove the old wire??
Postby sgturpie » Thu Aug 25, 2016 7:02 pm
this w/e I will get to Melb from Bendigo to see White Rabbit
sgturpie
Images: 0
Postby frank » Fri Aug 26, 2016 6:47 am
sgturpie wrote:this w/e I will get to Melb from Bendigo to see White Rabbit
Hi Sgturpie I looked over White rabbit at Blairgowrie. Looked like the back stay was ready to snap.
frank
Postby Iluka82 » Sun Aug 28, 2016 1:51 pm
Shaun wrote:I dont know a lot about furlers, but are you able to feed the wire in from top or bottom, & put a Sta-Lok fitting top & bottom, then remove the old wire??
I think each brand is different, but on iluka I had to remove the whole furler to replace the forestay. I had the mast out of the boat at the time. Each extrusion had nylon spacers to stop the forestay rattling inside the furler extrusions. I had to disassemble the extrusions and thread the wire through each section refitting the spacers as I went. Luckily I was able to carry the section from the boat yard across to the rigger and he swaged the top eyelet after I rethreaded the lot. I replaced all the rigging in one go, I used power drive marine in Williamstown (next to Hobsens bay yacht club) to remake the rigging, then refitted it to the mast myself. I was happy with their service.
Cheers Nick.
Iluka82
