Cockpit hole repair
Cockpit hole repair
Postby Troppo » Mon Jan 27, 2014 7:54 am
The back of Windchaser's cockpit had this fancy black on white art nouveau but I suspected it was not art at all but a cover up.
hole 1.jpg (134.15 KiB) Viewed 4103 times
Upon further investigation, under the guise of doing a reno, I found two mysterious holes. Maybe not too mysterious, perhaps access holes for the posts.
hole 2.jpg (332.87 KiB) Viewed 4103 times
Something was once screwed over the holes, don't know what. Oh, the smeared grey stuff around the holes is the sticky stuff from the tape. It does not sand off, only blocked up my sanding disk. It was hard to get off, I used my trusty chisel to scrape off the thickest bits then used a solvent, can't recall which one as I tried metho, turps and acetone.
Initially I was going to screw painted ply over the holes to seal them off totally. Then working in the quarter berth below the cockpit floor I realised that some breeze actually flowed through under there with the holes open. Extra ventilation is good.
Eventually I found something I thought would keep out most of the rain but let some air through. Under the edge is a strip of butyl mastic to stop leaks so it should keep water out except a little which may blow under through the slits. I also put a patch of flyscreen over each hole which stuck nicely to the butyl mastic around the edge. I decided to do that since after taking off the covering tape it was a week or so before I got the vents on and spiders loved it. Amazing build up of webs, big fat black spiders in residence. Since I was not making a covered entryway for spiders, I put mesh across.
hole 3.jpg (308.63 KiB) Viewed 4103 times
Another job done, only a million more to go. : )
Re: Cockpit hole repair
Postby Phillip » Mon Jan 27, 2014 3:13 pm
Louis,
I do believe those holes had inspection hatches.
See whitworths item 66043 page 116.
Postby bearmcnally » Mon Jan 27, 2014 3:59 pm
Arr ( Pirate talk ! ) Phil what about holes for the stero speakers ?
Bear :D
PS Troppo I raced a 16 foot skiff out of Middle Harbour that had artwork like that ! and it kept the water out ? :o
Postby DESIREMK1 » Mon Jan 27, 2014 4:27 pm
Hi Guys ,
I could definitely see a set of speakers seated in those 2 cut outs , obviously not what a purist Top Hat Owner would do !!!! Lol
Brad
DESIREMK1
DESIREMK1
Images: 4
Users browsing this forum: No registered users and 78 guests
