Seaka goes around Australia, 2015
Re: Seaka goes around Australia, 2015
Postby Troppo » Thu Mar 26, 2015 12:34 pm
frank wrote:I guess that would be one advantage with having an outboard engine.
Good point. I guess especially useful in some areas.
Since Windchaser has an outboard and since the Fitzroy River where she spends her time is dirty and croc infested, then I am glad I don't have to dive in to check the prop. Also, during flood with all the weed, it is easier to lift the outboard to check the prop than try and dive down and feel the prop. And who would want to do that when the flood current is racing past. I say 'feel' as you can't see 1mm in the dirty flood water.
Postby Shaun » Thu Mar 26, 2015 8:19 pm
Excellent point frank! :D :D
The offending lobster pot floats, impossible to see on a moonless night.
Between Trial Bay & Coffs Hbr
Drying out in Coffs Harbour marina
Postby percyverhance » Thu Mar 26, 2015 10:05 pm
Nice pics Shaun.Thanks for sharing.I like that canvas bag you set up for your dinghy Philip.Keen to see how it works out.What sort of inflatable are you cruising with Philip?
percyverhance
Postby Phillip » Fri Mar 27, 2015 5:24 pm
Well Shaun got back to Camden Haven on Tom's,[ex Tales] S&S 34
SHAUN LIKE THE EASIER RIDE AND I THINK HE"S THINKING OF A BIGGER BOAT :shock: :P :P
New post on my blog tomorrow 28/3
Postby Phillip » Mon Mar 30, 2015 4:41 pm
New blog up at
www.sailblogs.com/member/seaka
Percy, the inflatable is just a cheap $500 job from whitworths
Postby Shaun » Fri Apr 03, 2015 7:37 am
As I type this.... Seaka is raising anchor & setting off from Iluka to the Gold Coast Seaway 100nm.
Just spoke to Phil, he was waiting to avoid the strongest of the incoming tide before departing, there is a light SW 5-8kts that is forecast to turn E about 10kts.
Postby Phillip » Sun Apr 05, 2015 4:15 pm
Sunday 5th April
Well today I am reflecting in the sunshine, anchored in Bum's Bay Southport, mind you we are not going anywhere at present, let me explain.
As I have posted earlier I decided to wait until the weather window on Saturday 4th, this was in Iluka Bay, and then going on the Friday 3rd as the weather guru's had changed their minds, proved to be the right one. Unfortunately they forgot to tell the wind about it and during the entire voyage we had only light winds and in fact on Saturday in the Coral Sea, virtually none at all, which was important as you will see.
On that Friday morning with very light winds I raised the Main and Genoa sails while still at anchor then proceeded out of Iluka Bay into a flood tide against which we slowly proceeded to sea. By 0915 we were clear of the bar and motor sailing at just over 4 knots in the very light wind. I had to maintain 4 knots to arrive at Southport for the flood tide at 0800 on Saturday.
Conditions were very calm so out went the fishing lure but there would be no bites and we retrieved it late the next morning. Generally the sailing was good and by late in the afternoon, after 40 nm, we were passing Ballina and reporting into MR Ballina. The bar look OK from 2 miles out, but there was no way I was going in there after my last short visit in 2011, maybe I should have. Just after dark and 15nm later, we were off Cape Byron and reporting into MR Bryon Bay.
The next 25nm would take us up to Fingal Head and Danger Reef, which we would pass on the east side. During this part we had the first real AIS/R [Automatic Identification System/Receiver] warning. This turned out to be a large container ship approach from my stern but some 2nm to our starboard side. It passed safely, but without the AIS/R I would never have known it was there.
Now about 0300 that morning I was sitting inside when all of a sudden there was this smell of hot metal and steam! I immediately stopped the Nanni diesel engine and lifted the engine hatch. I was greeted by the smell of hot metal and steam. All was too hot to touch but I determined that all the coolant had been expelled from the engine. Shit! Well there was nothing I could do with everything so hot so got back to the cockpit and trim the sails, as that was all that was going to get us to Southport.
On Saturday morning at 0700 I reported into MR Point Danger and gave them an estimated time of arrival at Southport of 1500 hours and reported my problems asking that to be passed onto VMR Seaway Tower. So the gods are angry, then the wind dropped to nothing and here I was with no motor and only a slight northward current to get me to Southport. During the day I stripped off the windvane gear and set up the 2-stroke outboard motor to provide some sort of propulsion. We had 2 or 3 rain bands go through during the day and these provided just enough wind so that by 1430 we were off the Seaway.
Looking at the situation I thought I may be able to sail in right around to Bum's Bay and as I thought that the wind died for good, as it turn out. The decision was made when I observed that a yacht had doused all sails before going in, the ebb must still running which meant I wasn't going to sail in.
So for the first time I radioed into a rescue service with rescue in mind. VMR Seaway Tower was very businesslike and got all my details and Lat/Long saying they would send someone out as soon as possible. I used that time to clean up, lowering all sails and putting in two reinforcing lines back from my bow bollard to the winches on each side. It was not very long before they arrived and organised the tow.
"Keep directly behind us and pointed at us at all times" they said.
Telling them my hull speed was 5 knots [a little white lie, as it's actually 6.2 knots] we proceeded for the bar. They did keep to the 5 knots and we made it over the bar without incident. We were then towed up to Bum's Bay, crowded because of the Easter weekend, and found a place to anchor. I thanked the VMR boys and they got out their paper work and at $50 per half hour for one and half hours work with me I considered the cost very cheap. Never, never would I have made it in by myself without at least 10 knots of wind, which we still haven't had since I have been here, and a flood tide.
I spent the rest of the day tiding up, having a meal, and crashing for twelve hours sleep.
l this mean? Well I won't get a diesel mechanic before Tuesday at the earliest, so watch this space on that one. I have to get up to Horizon Shores at Jacobs Well to do my anti-fouling, that's on hold also until we see what's happened to the diesel engine, thou that might also be done at Horizon Shores.
One decision that has been made is that the round Australia Voyage will be limited to the Queensland coast this year, continuance will depend on how we are going later in the year.
Couple of short videos here:
http://youtu.be/H3PBZ8UFjrc
http://youtu.be/_PAJgiUGuHA
New photos in Gallery.
PS anyone know a good diesel mechanic in the Southport area?
Postby frank » Sun Apr 05, 2015 5:44 pm
Gees Philip do you have bananas on board. Bugger about your problems. I look forward to your posts just as I do with Robs on Sundowner. I know SFA about diesel motors but I've had a few outboards so I must say I'm really leaning towards an outboard when I finally get my Top Hat. The ease of just taking it ashore for repairs or at worst buying another one suits me. Anyway Phil hope you sort your troubles. Cheers Frank
frank
Postby Troppo » Sun Apr 05, 2015 6:17 pm
Hi Phil, I think you could easily go all the way around Australia, just keep that auxiliary motor out the front at the end of that rope.
Ok, if it was me, I would be very dismayed at the motor situation. However, you have picked a nice spot to break down.
When I bought Windchaser, she spent some time in the (expensive) marina near Bums Bay. I used to walk from there around and over the bridge to the shopping centre to get groceries. Taxi back usually as I was provisioning to come up the coast and too much groceries for a weakling like me to carry for an hour. Somewhere near there is a Kathmandu outdoor store from where I bought 1/2 price walking shoes as the el-cheapos I had with no padding did not handle the many hours of walking so was glad to upgrade. Also Whitworths and other shops within walking distance (if you have walking shoes).
Oh, in the big shopping center was a fast food shop among the others that sold roasts and vegetables and did a special deal with a drink and apple pie with custard desert. Some of the broccoli was overdone as veges sat in the bain-marie but it was the best value tasty and healthy meal I could find in the area (the softdrink was not a health alternative but oh well).
So, hope all goes well with getting that motor going.
I was watching the earth wind map when you were coming up the coast there and it did not look like good winds. Looked like convoluted winds as a low or something sitting there and a bit further out to sea the winds were from the north so not a good direction for you heading up the coast.
[http://earth.nullschool.net/#current/wind/isobaric/1000hPa/orthographic=-214.24,-26.68,1176]
Postby storm petrel » Mon Apr 06, 2015 12:45 pm
Sorry to hear your diesel is playing up. Wasn't it the Nanni that stopped your Southbound journey last time? Little diesels can by amazingly reliable ( I have seen some with 8000+ hours without a rebuild) or annoyingly fickle. perhaps yours came off the production line the day before the Cherry Blossom festival and the guys were not concentrating? Hope you can manage to think Zen and still enjoy the cruise.
Wishing you better winds,
Aruba (Phantom 32)
Ex-hatter
