Wanted - Toe Rail Car !
Postby Maggsy » Tue Mar 02, 2010 1:10 pm
Hi all,
Not sure if this is a common part on the Top Hat mark 3 as lots of bits on Sea Monkey seem to be fairly different. My jib comes round the shrouds and through a pulley which clips into a car on the Toe Rail. Obviously this does not allow me to bring the sheet in too tight, as it is outside the shrouds, but it works OK. I reckon it would be a good system for the spinnaker sheet, so I am thinking of fitting a track on the deck (which I have seen on other TopHats) and then use the toe rail system for the spinnaker.
This is where i come to a problem, I have only one car and the other one is missing. At present there is a d-shackle which is used, but makes adjustment a pain in the proverbial. I have asked around and checked out the second hand boat bits stores and no-one seems to have one.
Does anyone have one in their garage that they would like to sell to me? Or does anyone know where I can get one?
I have attached a photo for easy identification of the part - note the unusual side-plunger!!
Regards .... Maggsy
Toe Rail Cart.jpg (112.32 KiB) Viewed 5151 times
Maggsy
Re: Wanted - Toe Rail Car !
Postby Dolphin » Thu Mar 04, 2010 11:13 pm
G'Day Maggsy,
You could try the Marine Exchange, they deal in all things old and odd. They're only online now, they used to be at Sylvania in Sydney.
http://www.marinexchange.com.au/
Hope it helps, Greg.
