mast ladder wanted.
mast ladder wanted.
Postby IanS. » Mon Mar 18, 2019 8:11 pm
Any one have a mast ladder for sale, or that I could borrow / rent please.
IanS in canberra
IanS.
Re: mast ladder wanted.
Postby Tophat25mk2 » Tue Jul 02, 2019 8:44 pm
Mast ladder? Now there’s an idea,
Tophat25mk2
Postby IanS. » Wed Jun 24, 2020 8:45 am
I ended up buying a 10 metre sling based caving ladder. from ebay I will ad some lines to the bottom and a spreder at the top and will use this to replace the antenna. on Auriga. i also run a saftey line.
Doen t come wit a bag but thats easy to fix..
IanS.
Postby Miker » Thu Jun 25, 2020 12:05 pm
Ian, do you have a link to that ladder? Sounds interesting.....
Postby MichaelR » Tue Jul 28, 2020 8:56 pm
I have to go up the mast too..sadly to change the light bulbs. ...where did you get the ladder from????
MichaelR
Postby saintpeter » Thu Jul 30, 2020 10:03 pm
I made a sling ladder which might be similar to one for caving. I found it near impossible to use, as it did not remain neatly in front of the mast but slid off sideways, despite being tensioned top-to-bottom. It is back in the garage! Job not done.
saintpeter
Postby MichaelR » Sun Aug 02, 2020 11:32 am
I was searching for ladders also. Looked at ascenders/descenders, caving ladders, mast steps and the like..eventually went to Google and made my own... $20 for 30meters of 25mm webbing, some electrical conduit ($5 for 4metres)for step treads and a carribeaner($7)....works a treat just to change a light globe. ...will attach some pictures. ..my next addition is to add some sail slides to hold it into the mast.
MichaelR
