Fiberglass Dinghy - FOR SALE - Kogarah Area
Postby Topi » Sun Apr 27, 2014 9:33 am
We have a fibreglass dinghy for sale. It is a commercially made small blunt nose dinghy. It is 2030mm long x 1130mm wide. Good volume for a small dink, it is stable, has a motor cut out on the back transom with some reinforcing there.
White outer, cream inner with a rubber edging to reduce marks on the boats you pull up against.
It is in very good condition, has a few chips here and there but nothing major wrong with it. $300
No oars or extras, just the boat.
It is just light enough to be lifted by one person, just. Unless you are Buffed up at Gym then you can do it with one hand :)
Interested, then you can txt or call me on 04.03.78.26.31. I doubt that the messaging system on the forum will work for me as I am having an issue with notifications at the moment.
Also happy to swap for/towards a small long shaft outboard.
Topi
