Mast fittings
The mast has been cleaned up and coated with Nyalic. The plan is to be sailing on or before Australia Day. I have started putting the bits back on the mast. There were only 2 sheaves in the mast head (one for the foresail and one for the mainsail). I need and extra one for the Topping Lift (previously it had a fixed cable Topping Lift). I don't have a Spinnaker at present, but want to get one later. What fittings do you suggest I put on the mast? There was an eye at the top of the mast and a Riley block about half way up. John
