TOPHAT midship section
Postby spotswood » Sat Sep 24, 2011 8:18 am
I am in the process of buying a Tophat, and will be needing to transport it home to my workshop for a complete overhaul. To keep within the 8 foot transport width I am wanting to build a cradle which supports the boat under the bilge area, rather than uprights up past the topsides. This will assist with the topside repaint job also. To do this I need to have a scale drawing of the midship section. Can anyone advise me where I can get a drawing of the midship section. Thanks in anticipation. Spotswood.
spotswood
Re: TOPHAT midship section
Postby bearmcnally » Sat Sep 24, 2011 9:21 am
Hi Spotswood
Hope this helps ? I should get the copies back from the printers this week ? when I do I will post them a.s.a.p
Postby spotswood » Sat Oct 01, 2011 4:32 pm
Hi Bear,
I'm a bit new to all this, and only just now found my way to your reply re Tophat lines. I see you were really efficient and responded within the hour. I see from your photo of the lines that this is exactly what I need. Thanks so much. I look forward to your posting of the lines on here. I assume that's what is going to happen? Thanks in anticipation,
Spotswood
spotswood
