Cleaning sails
Cleaning sails
Postby SeaLady » Fri Jul 29, 2011 5:51 pm
Hi,
My sails are dirty a combination of things from rust stains to bird poo, general dirt and grease.
I have been told that soaking sails in a big garbage bin with water Oxalic Acid and Napisan will work.
Get them brilliant white again.
Has anyone tried this? Any other suggestions?
Re: Cleaning sails
Postby rob.lovelace » Sat Jul 30, 2011 5:53 pm
I commented on a blokes white sails and he said he soaked them in the swimming pool for a week, don't know if I'd try it though even if I had a pool.
Re: Cleaning sails
Postby Dolphin » Sun Jul 31, 2011 12:29 am
G'Day Dianna,
I looked up an old book Care and Repair of Sails, Jeremy Howard-Williams from Adlard Coles (how quaint, not using the internet).
Basically, Jeremy quotes from ICI chemicals in respect to Terylene but it is also applicable to Dacron.
Extract
Note that Alkalis can make the cloth more sensitive to UV light. Heavy stains need to be treated by specialist dry cleaners?
Many of the chemicals can be bought in a druggist( Chemist).
Avoid alkali based detergents on Terylene and Dacron if you can't rinse them out afterwards.
Detergent powders are frequently alkali based. Liquid detergents are less likey to have alkalis in them.
Large sails can be spread on a concrete apron and washed with hot water using bar soap or detergent. Any sail less then 150 sq ft could be immersed in a bath of 50 deg C and similarly treated. Do not rub away at any part for more than a quarter of minute.
If you cannot get rid of a patch of particularly heavy dirt you can soak the patch in straight detergent overnight.
If general soiling is still hard to remove soak in a solution of Sodium Metasilicate (WTF) and cold water,1 lb to a gallon. Do not allow the solution to come into contact with, galvanised luff wires, alloy slides, bronze thimbles, snap hooks or piston hanks.
As an alternative, you could put a solution of up to 6 oz of sodium hydroxide (Casutic Soda) into a bath full of water and soak it in that, don't increase the proportion. (Fancy a pomie knowing how to use a bath :lol: ).
Mildew,
Scrub with a stiff dry brush remove as much as possible, soak for a couple of hours in a cold solution of bleach (Sodium Hypochlorite) Domestos Brobat or Chlorox to ten parts water, a cup to half a gallon. Rinse afterwards and be prepared for only partial success.
Metalic stains
Stains caused by finely divided particles or rust and verdigris can be removed by the following 2 methods. Do not allow the solution to come into contact with gal wires, Iron, bronze and copper.
1 Immerse in a 5% solution of Oxalic acid, salts of lemon (WTF) dissolved in hot water. Hands and sails must be washed thoroughly as Oxalic acid is POISONOUS.
OR
2 Immerse the stained portion in a warm solution containing two parts concentrated Hydrochloric Acid per 100 parts water. Wash off thoroughly with fresh water.
End of extract.
It may be best to consult your local sail loft to find a better way. There is probably something on the market in a can.
I used the detergent on my genoa that was stained with the red dust from the 2009 dust storm and green moss and it didn't do much, but i used detergent and cold water on the lawn.
Hope it helps, take care.
Re: Cleaning sails
Postby Phillip » Sun Jul 31, 2011 9:40 pm
Greg,
What about blood stains? :shock:
PS: Blood is O Pos.
Re: Cleaning sails
Postby 8philip8 » Sun Jul 31, 2011 10:20 pm
:lol: what about a human body? :lol:
8philip8
Re: Cleaning sails
Postby Phillip » Mon Aug 01, 2011 9:26 am
:shock: It hurt like hell, didn't realize I was loosing the claret until I saw it on the sail. :shock:
MacKay Marina.
Re: Cleaning sails
Postby Dolphin » Mon Aug 01, 2011 7:09 pm
Philip, you must be having fun if you've got blood on the sails (Capt W Bligh).
Quote,
Blood will respond to soaking in one of the biological soap powders. There is a slight danger that optical brightners may react with dye stuffs, some special resins and also some ropes, so use a powder without brightners if you can find one. Keep adhesive numbers out of the solution or they may come off; this is particularly true when the sail is left to soak for a long period (overnight) for enzymes to digest the proteins.
Really stubborn bloodstains can be attacked by soaking in a 5 % ammonia and water (one cupfull to each gallon of water) If this doesn't work damp the stain with a 1 % solution of Pepsin in water acidified with a few drops of dilute Hydrochloric acid, allow to stand without drying out for 30 minutes and then rinse thoroughly.
End Quote.
Hope it helps.
Re: Cleaning sails
Postby SeaLady » Mon Aug 01, 2011 8:39 pm
Thanks all
I like the swimming pool idea.
At least it is bigger than my bathtub and I don't need to carry the sails upstairs.
May try a mixture.
Taa Muchly
Re: Cleaning sails
Postby SeaLady » Tue Aug 02, 2011 12:25 pm
Still thinking how you get your sails to the dry cleaners?????
Re: Cleaning sails
Postby Dolphin » Tue Aug 02, 2011 9:34 pm
Well that is what it said.
Quote;
THe advise on cleaning various stains given below is based largely on information kindly supplied by ICI fibres, of England which refers specifically to white Terylene but is also applicable to Dacron; dyed sails often need treatment by specialist dry cleaners or finishers (beware, for instance of using bleaching agents or solvents and don't use bleach on nylon of any kind) Never use galvanised of alloy containers, but stick to stainless of polythene (or porcelain or enamel, if they are not chipped).
End quote.
Greg, for what its worth.
