Angle of vanishing stability
Postby Shaun » Thu Jan 08, 2009 10:21 am
Does anyone know the angle of stability for TopHats I believe it to be around
130 deg . With 47% ballast ratio this sounds about right.I would be gratefull if any one has gone through the exercise.
Ray
You asked for it you work it out (laugh)
In the 30th Anniversary edition of Adlard Coles Heavy Weather Sailing Peter Bruce offers a formula for the calculation of an approximation of the angle of vanishing stability (AVS) using readily available data on a boat. The formula is:
AVS = 110 + ( 400 / (SV-10) )
SV is the screening value and is calculated by:
SV = B2 / (R x T x V1/3)
Expanding SV in the first equation gives:
AVS = 110 + ( 400 / (B2 / (R x T x V1/3))-10) )
B = beam of the hull (no rub rail) in meters
R = ballast ratio
T = hull draft at B/8 from centerline in meters
V = displacement volume in cubed meters
For the 10M these values are:
B = 10.85 ft = 3.31 m
R = .44
T = 1.63 ft = 0.50 m
V = 12,500 lbs = 5.53 cubed meters
AVS10M = 110 + ( 400 / (3.312 / (.44 x .5 x 5.531/3)) - 10 )
AVS10M = 131.6
By the formula the AVS for the 10M is 131.6 degrees. According to Bruce the formula is only an approximation and may be in error by as much as 15 degrees for some types. And indeed the AVS of 131.6 does not match with the measured LPS (limit of positive stability) for a particular 10M as shown on the USYRA stability calculation. The USYRA value of 123 degrees is lower by 8.5 degrees. The USYRA value is derived from tests and actual measurements of the boat. The AVS calculation is an estimate based on the actual test results on a number of "typical sailing yachts".
US Sailing has an AVS calculator on it's web site where the data may be entered to find the AVS using the formula from "Heavy Weather Sailing". On the web site they use a measurement for T (hull draft) that does not match with the formula in the book. They take it as simply hull draft rather than the depth at B/8 outboard from centerline. This will result in a larger value for T and thus a larger value for AVS. The difference for the 10M with the US Sailing value for T and the books value is an AVS of 135.1 vs 131.6. That's a pretty big difference and could move a boat from one race qualification class to another.
It should also be kept in mind that the AVS is a static measure of stability for a boat at rest in flat (calm) water. The angle alone is in incomplete assessment. The stability curve ( a curve of righting moment vs angle of heel) will show the relative stability of an upright hull vs inverted. This can indicate a boats ability to recover from capsize. The dynamics of a boat in motion in a seaway have large effects on stability. Any proper evaluation of a boats suitability to offshore sailing in rough ocean conditions must account for more than just AVS.
Recommend Message 3 of 3 in Discussion
Thank you for all that info whitsundaysun, like I said has any one worked it out or am I doomed to spend tonight on the calculator.
