solar v wind (or an S&S34?)
Posted: Mon Sep 06, 2010 9:14 pm
I'm considering which is the best, or most practicle method for keeping batteries charged. I'm going to replace my current temporary battery with something around the 70-100ah mark and rather than pulling it out to charge would rather use solar or wind.
I only need to power the nav and cabin lights (LED), VHF and AM/FM radio, sounder and some sort of plotter or if not a plotter, at least a GPS (speaking of which, the GP450X looks a good buy now it around $300) and the tiller pilot (running most of the time and probably the biggest user of power at around 1.5A at worst).
I currently (excuse the pun) have a solar panel which is either 10 or 20w, so virtually useless for charging. I believe a 40w panel will do the job, with 60w probably overkill, but maybe better to be safe than sorry. But the downside to this is the size, especially 60w. On the back of a TH maybe a little large, but a 40w should be ok.
I haven't researched wind generators to any extent, but imagine the output would be comparable, if not better (and more consistant given it's wind genarated) than solar, but again, are they a little large for a TH?
So....grateful if anyone has any opinions re solar panels v wind.
Or do I get my dream S&S34 so the 60w will fit!
Thanks in advance,
Scott.
Thanks in advance,
Scott.
