Slight water leak (salt)
Postby john lewis » Mon Jul 12, 2010 2:46 pm
Hi all i noticed the other day, under the stairs, looking back towards the stern, just in front of were the rudder shaft comes through,a small egg cup basin, full af salt water, so sponged it out, till it was dry, it took about a week, for water to form their again, not a lot about three to four ml, Has any one experienced this before?
Cheers John Lewis :o :o
john lewis
Re: Slight water leak (salt)
Postby auriga » Mon Jul 12, 2010 7:59 pm
John
I had the same issue, mine turned out to be a leaking bolt from the a bolt on the transorm, a little rain would seep through over a period of time and mixed with the general levels of salt in the cabin/deck to taste salty
If i were you id do a quick check of all the fittings in the stern after it rains and see if you can pinpoint the leak, if not it may be something else!
dan
auriga
Postby Tales » Tue Jul 13, 2010 8:57 am
Hi John,
Leaks can be very tricky to find.
If you dry it out next trip and sprinkle talcum powder around the water might leave a track when it does it again.
Postby john lewis » Sun Jul 18, 2010 5:05 pm
Found the leak staunchion pole dripping when raining!! :mrgreen:
john lewis
Postby Shaun » Sun Jul 18, 2010 6:27 pm
Good detective work John,
I have a couple of staunchion bases with the same problem...
& the fix i presume would be to remove the base, & squirt a pad of Sikaflex (or other?), nip up the nuts on the bolts finger tight...then let the Sika go off for a day or two & nip up the nuts from below, making sure that the bolt doesnt spin(2 person job) & break Sika bond around it, thats assuming you can get to the nuts below...
Anyone know a better way to do it?
shaun
Postby john lewis » Mon Jul 19, 2010 1:49 pm
I just run a bead of silicone around the base of the pole and a bit over the screw holes,works every time.
Cheers John (oberon11) Belmont South
john lewis
Postby Tales » Tue Jul 20, 2010 12:20 pm
If the stanchion base is a reasonable fit to the deck I recomend remove stanchion, clean up and seal with Sikkaflex and tightnen bolts. If you leave a flexible pad beneath, the stanchion will move and eventually leak again.
If the stanchion is not a good fit, either shape it to fit or make a pad of filled epoxy beneath and seal as above when it is set.
Users browsing this forum: No registered users and 43 guests
