Page 1 of 2
dinghy & electric motor
Wed Jan 27, 2010 10:40 pm
by 8philip8
Hi all
has anyone use electric motor on their dinghy?
does it work well?
"Sylph"
8philip8
Re: dinghy & electric motor
Thu Jan 28, 2010 9:29 pm
by Marinka
have not done that but funnily enough was asking myself the same question today - it would seem that for use of a tender it woud be ideal if you don't want ot mess around with petrol and outboards.
Fri Jan 29, 2010 6:15 pm
by 8philip8
electric motors are not cheap! a good one for salt water use cost somewhere over $1000
but they are light,small, easy to hook up & remove,
BUT have they got enough power to push the dinghy & 2 person?
"Sylph"
8philip8
Fri Jan 29, 2010 9:03 pm
I see people trowling with electric motors from time to time near where I am moored. They seem to push the boats quite slowly, but these are fishing tinnies with outboards. I overtake them easily in my oar powered dinghy.
Mon Feb 01, 2010 9:44 am
Trolling motors are different to proper transom mount electric motors.
I've seen a two man rubber dinghy going almost as fast as my 3.3 Mercury on our slat floor dinghy with two aboard.
The Minn-Kota information states that their motors do about 8kph on small dinghys.
It all depends on how much money you want to spend and whether you want to carry a battery or a can of fuel.
There are larger "pod" styles that are replacing traditional forms of propulsion too, having up to 10 hours of power before a charge and getting quite high speeds.
Here are some references for your enjoyment....
http://www.mindspring.com/~jimkerr1/sebc&t.htmhttp://www.electricboats.org.au/Michael
Mon Feb 01, 2010 8:12 pm
Philip,
Spoke to the guys who own the other Mk1 at Camden Haven River.
Said they had the $200 Minn Kota, which would do about 2km on
a 1/2 size car battery before recharging.
But, isnt' there always a but, if the plastic prop hit anything, even sand, it would shatter!
I noticed they had a 2hp petol outboard on their dinghy today!
Tue Feb 02, 2010 6:24 pm
by 8philip8
hi Philip SEAKA
Minn Kota for $200, might be a toy one,
there is always a BUT, whenyou try something unusal.
8philip8
Tue Feb 16, 2010 1:54 pm
by robf
Hi
I have used an electric "thruster" motor using a jump-start battery in the past with good success on the 400m run out to the boat on an inflatable dinghy. Now I have a fibreglass dinghy on a rack near the mooring I simply use the manual labour approach and row my way out - less gear to take!
I've measured the drain as being around 30 amps continuous, which in theory would give 15 minutes running to drain a 15 amp-hour battery to 50%. They are reliable and with no fuel to leak make a nice alternative to the heavier 2 hp outboard. I think I paid about $250 about 10 years ago for the motor, and have had several battery replacements in that time (the cheap jump starters from K-Mart or auto stores probably come in from China).
Cheers all
Rob
Isabella II Pittwater
Tue Feb 16, 2010 9:10 pm
by 8philip8
hi Rob
have you got any photos?
8philip8
Wed Feb 17, 2010 12:09 pm
by robf
Hi 8philip8
I don't have photos to hand, but could take some if you like. I've since sold the inflatable dinghy but do remember getting the electric motor from Whitworths - much less than $1000!
Rob
