One less Top Hat?
Posted: Wed Oct 07, 2009 7:20 pm
The other day I was down at Williamstown doing my usual check of Sombrero and not far from my boat I could see a mast sticking out of the water with no boat below. Being a curious type, I went down the next day and arrived in time to see my friend and his crew on the mooring service barge endeavouring to raise what turned out to be a cold moulded Top Hat that I had previously included in my register of Top Hats at Hobsons Bay. The job took most of the afternoon, mainly because, even with three pumps running, it did not want to come to the surface. I joined them in their endeavours and the reason for its reluctance to leave the bottom soon became apparent. It would appear that it sank because the toilet seacocks were not closed, and that as it had settled, because of neglect the boat filled with water, leading it to sink. The barge crew did manage to get the stern clear of the water but, on close inspection, the stern had broken away. Another barge was brought into action to raise the bow and disconnect the mooring. the job was made difficult, because, as fast as the water was being pumped out it was re-entering through the front hatch and the dorade vents. Helped by the two barges the boat was moved to the Parks Victoria Jetty. However, It sank again as soon as the pumps were stopped. I do not know what the boat's name was because there was no transom in it. The next day I was talking to my friend from the barge and he told me that the boat was absolutely full of rot and it had started to break up as they were trying to raise it and move it to the Parks area. Pevious to this day, I would have said that while looking neglected, it looked like, with a bit of TLC, it could have been made into a pretty looking Mark 0. There are some lessons to be learned fom this when looking at cold moulded hulls with a view to making a purchase.
My personal reminder, make sure the seacocks are closed and that, if there are deck and cockpit leaks, as was the case of the one I have written about,make sure it is pumped out regularly until the faults are rectified.
SOMBRERO H1421.
SOMBRERO H1421.
