self righting ability
Postby scott » Sun Jul 19, 2009 1:42 pm
Hi all,
Does anyone know what the self righting characteristics of the Top Hat are like? Anyone been knocked down? How did the boat respond?
I'm guessing as the ballast ratio is nearing 50% (I think that's right), it should right reasonably well. Hopefully....
Scott.
Scott
(ex) TH MkIII
scott
Re: self righting ability
Postby Tales » Mon Jul 20, 2009 1:15 pm
Nick Creech sailing in the 1978 Solo Trans Tasman in White Tie (MkII Top Hat) was knocked down 12 (perhaps 14 times) in the aftermath of Cylone Hal.
Winds 70 knots for nearly 24 hours out near Lord Howe Island.
I have sent it to Site Admin to put on the web for us but believe there is some complication.
If you want to read about it I can send you a PDF file. Also his 500 nautical mile qualifier story.
Postby Yogomana » Mon Jul 20, 2009 9:24 pm
I really hope you can upload the file or post a link as it sounds both terrifying and comforting.
tom
Yogomana
Postby Shaun » Tue Jul 21, 2009 8:26 am
Hi Tom,
Could you please send me the file to anzacforce @ yahoo dot com
shaun
Postby admin » Tue Jul 21, 2009 8:29 am
Sorry guys
My bad, totally forgot about this
Below are the two file links, will set them up on the docs page shortly
http://users.tpg.com.au/kateh1/tophat/files/transtasmanqualify.pdf
http://users.tpg.com.au/kateh1/tophat/files/transtasman.pdf
Postby Tales » Tue Jul 21, 2009 8:53 am
Thanks Admin!
Nick is still about although at present he has some health issues but has been incredibly helpful to me in working out how to set up Tales for offshore work.
White Tie likewise is still around and was for sale with Lamore recently. She looks a bit sad and has had a few changes since Nick sailed her. A pity really. I bet there is not another Top Hat (or Top Hat Skipper) come through as much rough weather.
Postby scott » Sat Jul 25, 2009 9:46 pm
Thanks Tom / Admin,
These are great articles, though after reading them and the book Heavy Weather Sailing, I'm reluctant to take even a bath, let alone a sail!
Thanks again,
Scott.
Lapse of Reason
Jervis Bay
Scott
(ex) TH MkIII
scott
Postby Kal » Fri Oct 09, 2009 11:25 pm
It is only a rough indicator, but using the formula: Capsize Ratio = Beam / (Displacement / 64)0.333 and the top hat data from this site, you get a figure of 1.7
"In extreme conditions, all sailboats, even those with heavy deep keels can capsize. The question is how easily. The Capsize Ratio, a very crude estimate, was developed by John Rousmaniere, on the assumption that heavier narrower boats are harder to capsize. Numbers range around 2. Low is good"
I got this formula (and quoted the above text) from http://cruisingresources.com/crs_specsfaq and worked it out so I could compare the figure to the other boats in their 'boat finder' database
I'm not sure if this exactly relates to the question regarding self righting characteristics, but it at least gives a rough reference with which to compare to other sailing boats.
Kal
