Top hat overall height
Postby frank » Fri Mar 11, 2022 10:03 am
Hi All.
Does anyone have a rough measurement of a Mk1. From bottom of keel to roof top. Need it for info for the truck transport. Cheers Frank
frank
Re: Top hat overall height
Postby steve » Fri Mar 11, 2022 3:47 pm
Hi Frank,
From the drawings of the Mark 3 in the gallery, it looks like a Mark 3 is between 2.5 and 3m. I don't think a Mark 1 will be much different.
steve
Postby frank » Fri Mar 11, 2022 5:57 pm
steve wrote:Hi Frank,
Thanks Steve. I would think you're correct. Looking at side on views , and knowing the draught it's a pretty good estimate.
frank
Postby Phillip » Sun Mar 13, 2022 12:47 pm
No that's not correct.
The Mark 1 cabin top is about 6" higher as formit [on mk 1 & 3] lowered the cabin top as well as raising the Cockpit floor by 6".
That's why you see canopies on Mk 2 & 3, but rarely on Mk 1's :P
In fact the Mark 3 cabin top is lower again than a Mk 2.
All hulls are 2m from keel to gunnel
Add 400 to the mast Bridge on a Mk 1. I suspect that is about the same for all marks.
I haven't actually measured vertically from the mast bridge to a point that clears all push/pullpits and the main sheet rail.
If you rest your mast on the push/pullpits you will have to add a bit.
Postby frank » Sat Mar 19, 2022 3:22 pm
Thanks Phillip
frank
