How to make forum work again
Postby dism » Sat Mar 24, 2018 11:41 am
All
To make forum work again:
Via phone - pull battery out of phone for 30sec, should work on restart
Via pc - go to internet settings and clear cache and stored page settings
Apparently called flushing DNS (as per other thread Phillip/Shaun info).
Now forums work again!
dism
Re: How to make forum work again
Postby Shaun » Sun Mar 25, 2018 4:37 pm
Yes, it's good now.
Here's how to DNSflush if on windows 7, got this from the new hosting company.
Please refer to the instructions on how to FLUSHDNS below:
### Windows® 7
To clear your DNS cache if you use Windows 7, perform the following steps:
1. Click _Start_.
2. Enter `cmd` in the _Start_ menu search text box.
3. Right-click _Command Prompt_ and select _Run as Administrator_.
4.
Run the following command:
`ipconfig /flushdns`
If the command succeeds, the system returns the following message:
`Windows IP configuration successfully flushed the DNS Resolver Cache.`
Postby Shaun » Mon Mar 26, 2018 8:24 am
To DNSflush on Windows 10:
1. Hold down the Windows key and press “R” to bring up the Run dialog box.
2. Type ipconfig /flushdns then press “Enter“. (be sure there is a space before the slash)
That's it.
