Slab reefing solution
PostPosted: Thu Apr 21, 2016 9:34 am
Found this little beauty of an idea on a blog site, enabling you to slab reef without requiring a visit to the mast to remove 1 or 2 of the mains'l slugs around the reefed main tack cringle.
What do you reckon?, cheers
Second story from top of this page:
Small diagram showing the laced tape /belting through slugs,
http://snowpetrelsailing.blogspot.com.a ... date=false
Re: Slab reefing solution
PostPosted: Thu Apr 21, 2016 4:12 pm
Interesting idea, Shaun. I have yet to set up a reefing system on Windchaser :oops: so I am keen to see how other people do it.
Oh, I should say, if I think I need to reef, I just down the mainsail and use the furler to control the jib. Not the best which is why I am in the process of setting up a reefing system.
PostPosted: Thu Apr 21, 2016 9:36 pm
I use a single line reefing for each reef. That means I have two reefs in the mainsail.
All easily controlled from the cockpit. I'll try and find some photos
[I'm having trouble with the computer in which they are held so maybe a couple of days]
PS, I devised a way to get the sail slugs all the way down to the boom, will repost that also.
