Adjustable backstays
Postby Shaun » Wed Jan 21, 2009 8:13 pm
From: Karl010203 (Original Message) Sent: 11/08/2008 15:24
Who has an adjustable backstay?
I saw one that on a really tidy tophat recently and thought I wonder if it can be added to a standard rig or if needs to be set up specifically for it. It was a simple tensioner on the split backstays - not hydraulic or anything.
Do you have one on yours, is it worthwhile for cruising? How did it enhance performance?
Recommend Delete Message 2 of 3 in Discussion
Hi
I had a fiddle block (4:1) onto a 2 :1 giving me 8:1. I have added a further 2:1 giving me 16:1. when tensioned on going up wind it decreases the amount of sag in the fore stay, This gives a noticeable improve in pointing. I then release downwind which gives a small increase in top half main depth and give a fuller headsail.
Phil
Recommend Delete Message 3 of 3 in Discussion
Hi Phil
Do you reckon it is possible to add something similiar to a standard set up without too much stress... I would like to try it but not sure whether it would add additional stress or if the rigging should be altered to allow for it.
I can't see why not but am a bit concerned I might be overlooking something...
Karl
