small genny + bat + inverter?
Does this have any advantages in regard to electricity on boats:
Use a smaller generator to charge the batteries and use a bigger inverter for the occasional use of bigger 240 volt equipment. I'll explain, but I'm not sure if I am being clear so please persevere:
A Honda or Yamaha generator 1 kw (rated .9) genny weighs about 13 kg, a 2 kw (rated 1.6) one 21 kgs.
My electric drill is 1,000 watts, vacuum cleaner 1,800 watts. So, to run them I would need a 2 kw one, the bigger one. However, I don't run that equipment for long.
As an alternative - and this is what I would like your opinion on - when I need to use the bigger equipment I could run the smaller generator output through a good-sized 240 volt charger into my batteries and have a 2 kw inverter supply the required juice. So long as I don't use the tools for hours then I shouldn't drain the battery.
The benefit, as I see it, is that I dont' carry around the extra capacity generator for the few times I need it. Passing a 13 kg genny up and down to the dinghy is much more do-able than a 21 kg one. : )
What do ya reckon? What's the pros and cons?
