Hell of a storm
Re: Hell of a storm
Postby lockie » Thu Jul 17, 2014 8:40 am
Martin;
Re your gearbox, I hope this doesn't happen to to you, and maybe it won't if the salt water was only in there for a few days. However, mine went undetected for a couple of months, by which time the corrosion caused slipping of the forward cone clutch. I was unaware of the cause, and mucked around for months trying to diagnose it before finally sucumbing and pulling out the box. I disassembled it at home and cleaned up the cone surfaces, which despite my fears was a pretty straightforward job. Probably took me a day and a half all up, but if/when I do it again, I'd be able to nail it in a day. I'll probably have to eventually as it has a bit of bearing noise, and a slight leak if run for more than a few hours. Not surprising given the corrosion.
PM me if you need more info.
Cheers, Graeme
Re: Hell of a storm
Postby genda » Thu Jul 17, 2014 11:22 am
Hi Graeme
Thanks for responding re the box on Genda (That sounded ruder than it should have) I will flush it out a couple more times and keep an eye on it. the water would have been there for two weeks Ouch !
Phillip your windows look outrageous, mine look like something out of Raders Of The lost Ark, can't wait to have a crack at them.
What thickness Lexan did you use and are they all the same shape or do you cut them using the old window as a template.
Cheers Martin
genda
