Bear's BMTROUBLE D7
Re: Bear's BMTROUBLE D7
Postby bearmcnally » Wed May 02, 2012 5:41 pm
Hi Gramps
The dropped nuts weren't a problem Greg wears underpants ! Egret II has a new tank and fresh fuel.
Make a note: Diesel is no good as a mouth wash or a cough elixir
Postby Gramps » Thu May 03, 2012 10:19 am
:lol: You crack me up till my sides ache Bear, but that is a damn sight less painful than cracking nuts!
Sean
Gramps
Postby Dolphin » Thu May 03, 2012 7:26 pm
Bear needs a tune up Sean.
He only gets a few minutes to a mouthful of diesel and then he stops working.
The fuel is gel in the fuel filter.
I also dropped 10 litres in to top up the fuel in Bears tank. I could see that I got a load of bad diesel from the local servo, its got quite a lot of fungus in it. I will look into the tank and sample some tomorrow to see if I have any fungus in my tank. The aglomerator is clear on Felicite. I will use diesel conditioner to cure the problem.
Postby Gramps » Fri May 04, 2012 1:34 pm
Dolphin wrote:Bear needs a tune up Sean.
He only gets a few minutes to a mouthful of diesel and then he stops working...I also dropped 10 litres in to top up the fuel in Bears tank
He is topping up with the wrong fuel Greg, he should stick to alcohol although too much of that will also stop him working!
Sean
Gramps
