Yanmar engine
Re: Yanmar engine
Postby Dolphin » Sat Jan 01, 2011 2:13 pm
Happy nEw yEr tio everi bodi,
Mark, Bear mentioned about fitting an electric motor to a Top Hat. Being an Electrical tech, not a diesel mechanic, does anyone know anything about refitting to electric drive? I wonder if it would be practical? Maybe you could replace the sails with solar cells. :lol:
Re: Yanmar engine
Postby storm petrel » Sat Jan 01, 2011 4:53 pm
I believe the development of high field strength rare earth magnets has enabled permanent magnets to be used in small electric motors making them much more efficient and powerful (for their weight). I have read that many displacement yachts have gone this way (particularly in the USA). The downside is the need for a battery bank and an operating time that is limited by the size of your battery bank. Nevertheless, it seems several hours of running is possible with a 10HP electric motor, that with the required the battery bank would weigh no more than a diesel. By placing the the batteries down low in the hull it might even make sailing more efficient and give you more usable space. They tell me that electric motors are quiet, reliable, efficient, are low maintenance, don't smell like diesel and don't produce greenhouse gases(at the boat). You would need a good solar set up or wind generator to make sure your batteries were charged between sails(or access to a power point). Most of us only use motors for an hour or less if possible when we we go sailing, so the electric option has quite a bit of appeal. I suspect re-powering with an electric system might even be cheaper than re-powering with a new diesel (and the prices of electrical systems should continue to fall.)
Check out the neat Bell-Mann marine electric motors at: http://www.ecoboats.com.au/productrange.php
(Note that I have no connection with this or any other company.)
Re: Yanmar engine
Postby Dolphin » Sat Jan 01, 2011 10:59 pm
May be worth keeping an eye on developments Mark.
I also like your pun, "I have no *connection* to the company" !
I have used an electric outboard on a reasonable sized dinghy running around here and it is amazing how powerful it is. Nothing like a 15HP but none the less, and considering fuel etc it may pay for itself.
Re: Yanmar engine
Postby Shaun » Sun Jan 02, 2011 6:14 am
Thats certainly interesting as technology develops, could be a viable option, to go solar-electric.
Theres a Top Hat for sale at the moment powered with an electric motor & 140 watts of panel.
http://www.boatpoint.com.au/boats-for-s ... ?R=9640226
Re: Yanmar engine
Postby storm petrel » Sun Jan 02, 2011 10:17 am
Check out the Torqueedo 9HP electric outboard and the information about performance on a yacht at:
http://www.youtube.com/watch?v=Ogel0KYPIwE
At 18Kg I would even consider going from an inboard to an outboard!
Re: Yanmar engine
Postby Dolphin » Mon Jan 03, 2011 9:49 pm
Food for thought.
I've even considered a steam engine. But it might be a bit hard on the misses shovelling all the coal.
