where to stow the door(washboards) on MK1
Re: where to stow the door(washboards) on MK1
Postby Gramps » Mon Nov 28, 2011 3:18 pm
So many options on a Mark 1. I can also stow mine under the cokpit seat on the port side. The lower board sits inside the top board and the bottom of the top board rests above a timber bracket at the aft end of the berth. The top end sits snugly against a piece of curved timber under the bulkhead with a simple wooden twist handle to hold it in position.
In practice I use the starboard locker. Dead easy!
Sean
Azzura
Gramps
Postby bearmcnally » Mon Nov 28, 2011 4:40 pm
SO SIMPLE AND EASY ARE THE MK 1's
Postby Phillip » Mon Nov 28, 2011 7:17 pm
Tom,
Forget the 2's and 3's here is how I do it!
Just note that I have turned the frame around 180 degrees so that you can see the construction.
There is a 25x25mm timber bead attached to support the locker floor.
Click and save photos to your files to see them better.
Added a third photo showing doors in frame.
Doors in storage.
Frame out of locker.
Frame in locker.
