Gypsyrider, I am not exactly answering your question here, but just giving you some idea of my experience with trying to get a boat free of osmosis and what happened next. I certainly think you should be wary of osmosis but it doesn't necessarily mean a boat is no good.
My old Mk 2 Windchaser had a survey done a year before I purchased saying no osmosis. When I had her up on a slip, I noticed some old and large osmosis blister repairs. A year later when up on the slip again I paid more attention as I saw tiny blisters up to 20 cent size on port side of hull, practically nothing on starboard side. Probably there the year before but now a bit bigger and I was looking harder. To confirm osmosis, I punctured blisters with small sharp screwdriver. Dark smelly fluid leaked out.
- osmosis02.jpg (319.39 KiB) Viewed 4426 times
- osmosis03.jpg (431.3 KiB) Viewed 4426 times
Photos show port side as only a couple on starboard side.
Ground out shallow depressions to remove affected materials, flushed with fresh water several times over a few days then let it dry out for a few more days while doing (lots) of other repair work. Then did the standard repair with brushing on epoxy, then a layer of fairing epoxy stuff that can go under the waterline, sanded back, primed and painted. The next year there was no problems. Year after that I had sold her so don't know if any more osmosis started.
- osmosis04.jpg (449.34 KiB) Viewed 4426 times
- osmosis07.jpg (411.66 KiB) Viewed 4426 times
- osmosis08.jpg (400.78 KiB) Viewed 4426 times
From my experience, the small osmosis blisters were mostly cosmetic. A couple of the bubbles did go a bit deeper than I was happy with but mostly they were shallow and the fibreglass is thick. The evidence of some repaired old big osmosis spots was a concern as I wondered if the small osmosis blisters would just keep growing. The osmosis repair I did was simple enough BUT, time on the slip to hopefully allow the hull fibreglass to dry out a bit costs money.
