inboard engine and shaft fitting
Having troubles using the site? Need a little help with technology? post your questions here
Postby 20126811 » Thu Oct 09, 2014 8:21 pm
Is their any drawings available to fit shaft and inboard into a mk2 tophat that hasnt had a inboard fitted only has provision at the moment for outboard
20126811
Re: inboard engine and shaft fitting
Postby RodM » Fri Oct 10, 2014 1:14 am
Don't even think about it. For the cost of dry stand time, drilling and glassing and fitting a shaft tube, through hull fittings and engine beds, prop, shaft, and motor plus electrics and fuel tank (I think that's about it), you'd be better off buying another Toppy with an inboard.
Cheers, RodM
RodM
Postby Phillip » Fri Oct 10, 2014 7:07 am
I tend to agree with Rod, there are plenty of Top Hats out there that have inboards.
Would be cheaper to re-engine [if necessary, with a re-conditioned motor] one of them.
Plus the value of Top Hats is too low to justify the expense.
Return to Tech Support
Users browsing this forum: No registered users and 2 guests
