Mast Climbing
Posted: Thu Aug 05, 2010 8:32 pm
Hi,
What do you use to climb the mast?
Yesterday i connected the main halyard (which is a block&tackle arrangement), to my harness, also with a Prusik knot from my harness to the pull line, with a Klemheist knot around the mast as a safety backup that also doubled as a foot hold, this was quite easy to do.
However an improvement i think would be to haul a double block & tackle to the masthead, again with a Prusik knot to the pull line, again with a Klemheist knot around the mast....anyone tried this? It really seems just too easy , am i missing something?
Possibility of using the mainsheet blocks, if they are high rated.
I was using a 14(or 16)mm static abseiling rope.
shaun
shaun
