The Danger of being underpowered.
Postby storm petrel » Wed Oct 02, 2013 6:49 pm
A colleague at Marine Resucue Central Coast told me they had to rescue a gent in a Top Hat this week. He had a small outboard and was motoring under the Rip Bridge when the wind suddenly strengthened. His outboard was unable to make way against the wind and currrent and he ended up trapped against the side of the bridge until Marine Rescue arrived to tow him off. He was very shaken by the experience apparently.
We have had some strong winds here over the past couple of months.
Moral of the story is that you should check the forecast carefully before heading out and try to have enough power at hand - sail/motor to get you out of danger. I am not sure if he had tried to deploy an anchor or raise a sail to avoid the danger. The boat was a but a bit beaten up. I suspect it was quite a bit worse than Philip's Swansea bridge bump last year.
safe sailing,
Re: The Danger of being underpowered.
Postby Phillip » Wed Oct 02, 2013 9:27 pm
Brush Mark, Brush, not bump! 8-)
But I do know how he felt, not good. :shock:
Postby RodM » Thu Oct 03, 2013 8:14 am
Its not just being underpowered which can lead to bridge troubles. The link below demonstrates the dangers of mast eating bridges...
http://gcaptain.com/sailboat-beat-bridg ... -incident/
Cheers, RodM
RodM
Postby storm petrel » Thu Oct 03, 2013 10:15 am
Rip bridge has 17m clearance and does not open so masts bigger than that cannot get up to the Gosford Broadwater. As to the video; Why would you keep motoring towards a closing bridge?? What was the guy behind him thinking who was also powering towards the bridge?
Postby Dolphin » Thu Oct 03, 2013 3:28 pm
Brush or BUMP the Roads and Maritime Services have only just replaced the wooden piles with a HUGE bull bar type structure that took 6 weeks to install, using a floating crane two barges 2 heavy lift mobile cranes and about 10 to 20 workmen. All because a Top Hat hit the bridge.
re the video, the boat made it through the bridge.
Postby Phillip » Thu Oct 03, 2013 5:02 pm
Wasn't me Greg, must have been someone else! :lol:
Postby storm petrel » Thu Oct 03, 2013 6:25 pm
Is the bull bar made of soft rubber or steel? Wouldn't the wood be better to bump?
Postby Dolphin » Fri Oct 04, 2013 10:01 am
Sure Phillip, "a big boy did it and ran away"!
If you blokes keep breaking our toys and running aground we'll keep the bloody bridge closed! :lol:
Postby RodM » Fri Oct 04, 2013 12:41 pm
I'd heard about 'turning back the boats,' but I hadn't realised it applied to Top Hats!
RodM
RodM
Postby woodsy » Sat Oct 12, 2013 9:25 pm
I pushed a friends motorless yacht under the Brooklyn bridge with my tinny. Mast was too tall so I used the same technique as in this video.
http://www.youtube.com/watch?v=CInYj5P4evA
woodsy
Return to Safety
